Page 1 of 2
Posted: Fri Sep 29, 2006 11:00 am
by fredsub
I have resoldered the wires to it, replaced a resistor, and the thing is still playing up..........must be full of dry joints, last time i broke the clips too:mad:
Posted: Sat Sep 30, 2006 12:34 pm
by r00fi
I haven't removed mine yet, but if there are any electrolytic capacitors on the board, try replacing them too. They are notorious for drying out.
Posted: Fri Feb 09, 2007 11:07 am
by r00fi
Clock fix
This resistor is in the supply (probably for a Zener diode) and gets hot.
Eventually leads to solder failure.
Resoldered and is now perfect....
Posted: Fri Feb 09, 2007 11:19 am
by Alex
what are the specs of that resistor? mine is fully stuffed!
Posted: Fri Feb 09, 2007 1:01 pm
by r00fi
I have a high res version of the pic but can't read the exact ohm value written on the pcb. It's definately 2 Watt, and has 820J stamped on the resistor (820 ohm???). You could try a 1K 2W or maybe someone has a clock laying around the garage that they read the value from?
Posted: Fri Feb 09, 2007 2:06 pm
by Matt
There is one resistor that always burns out just wack a bigger wattage one in the porblem goes away.
Re: L series clock help (RX turbo)
Posted: Tue Nov 27, 2018 1:07 pm
by L-Rex
FYI, the resistor value is 750 Ohm, 2W.
Posted: Thu Nov 29, 2018 12:30 am
by pitrack_1
I'd just like to point out 11.75 years is an awful long time to wait for a reply (and one of, if not the, longest I've seen on a forum anywhere)!
Posted: Thu Nov 29, 2018 6:44 am
by L-Rex
pitrack_1 wrote: ↑Thu Nov 29, 2018 12:30 am
I don't believe in rushing things...
Posted: Thu Nov 29, 2018 10:42 pm
by pitrack_1
L-Rex wrote: ↑Thu Nov 29, 2018 6:44 am
Of course not- all good things take time. Especially on a clock thread!!!
Posted: Fri Nov 30, 2018 3:18 am
by L-Rex
pitrack_1 wrote: ↑Thu Nov 29, 2018 10:42 pm
LOL. I see what you did there, and I'm back for seconds...
Posted: Fri Nov 30, 2018 11:49 pm
by pitrack_1
L-Rex wrote: ↑Fri Nov 30, 2018 3:18 am
Seconds... Hang on a minute, I could go on for hours...
Posted: Sat Dec 01, 2018 6:47 am
by L-Rex
pitrack_1 wrote: ↑Fri Nov 30, 2018 11:49 pm
I had better
watch what I say next...
