Electric Winches on an L series?
Posted: Thu Jul 13, 2006 10:24 am
by Sideways Subaru
Heya all,
was brousing the trading post this morning when i came across this pic of a subaru with an electric winch on the front.
anyone seen/installed a winch on an l series? are they really practical on a suby for off road duties? just tossing some ideas around.
Big Al
Posted: Thu Jul 13, 2006 11:31 am
by BlackMale
In the past i have seen a picture of Mudrat’s rig (from this board) with 1 on the front.
To answer your other question we have been thinking about the idea as we do a bit of 4WDing by ourselves and on a few occasions could have used this to get ourselves out of trouble. Just do you homework and evaluate for yourself as the winch option definitely has its advantages and disadvantages.
I will be interested in other input though.
Posted: Sat Jul 15, 2006 12:33 am
by Suby Wan Kenobi
I can see no reason why a small winch would not be out of the Question on an L series as they had optional winches for the MY series
Posted: Sat Jul 15, 2006 9:36 am
by Wilbur
I really hope that one is braced back to the chassis or the bullbar will be pulled off when you use it. I think that one may have been used to getting a boat onto a trailer........
Posted: Sat Jul 15, 2006 11:01 am
by fredsub
right,theres something disconcerting with where that one is shown fitting....
thats a roo bar, and the way they fit up, can't see how you can practically use a winch from that point - strength wise.
And yeah it does look like one of those cheap boat winches.......
but maybe for a lightweight sube its quite alright?
should work all right off a replacement bar tho.
Posted: Sat Jul 15, 2006 7:24 pm
by SuBaRiNo
What about making a winch set up that is made to attach to your tow bar on the rear. Detachable so you only fit it when needed. Should be strong enough there and still more than usefull in some situations.
Dave
Posted: Sun Jul 16, 2006 5:45 pm
by twc
Someone already has .
You can buy stock brackets to fit various makes of winches to attach to .
Most people ive seen with this set up have a towball installed /fitted front and back of their vehicle so the winch can operate from either end and allows the winch to operate at an angle to the vehicle more safely(apparently)
Posted: Mon Jul 17, 2006 12:21 pm
by fredsub
seen them boat winches cheap at Aldi - but i think i recall them rated at 750kg (or was it 1750kg?), probably not enough eh?
Aldi have got some 4wd stuff atm, a snatch strap kit $75....
Posted: Mon Jul 17, 2006 8:37 pm
by MUDRAT
Your winch capacity should be around 1.5x tare weight.
Mounting the winch to a 50mm reciever and using it in the tow-bar is an excellent idea.
To mount a winch to an L series bullbar you really need to brace and strengthen the mounts, even tie bullbar back to the engine crossmember.
