2003-2009 Outback Rear Interior Dome Light
thevagrant
Post by thevagrant » Sun Sep 11, 2016 6:16 pm
Hi All.
My problem is the rear interior dome light isn't coming on at all, whether I open the side doors or the tailgate. It also doesn't come on when using the manual switch on the rear dome light assembly.
The centre dome light works normally when opening all doors including the tailgate. So opening the tailgate does turn on the centre dome light but not the rear dome light.
I replaced the rear dome bulb but it still doesn't turn on.
Thanks.
Post by TOONGA » Tue Sep 13, 2016 2:20 pm
does that model have a switch on the light, if so that could be the problem, or a bad earth / positive wire. have you tested the circuit for power?
