New Hi Beam lights on 90 Brumby
Posted: Wed Jan 08, 2014 8:50 pm
Recently bought a Brumby 1990. Great ute. While installing dual battery setup, I noticed two problems.
1
The inner hi beam headlights are controlled by a relay , but get powered directly from the back of the generator. A fused ( 20 amp ) wire from generator to lights.
BTW both fuses were blown and I quickly blew 15 ' s I put in as well . Should I leave as is , or take power from battery terminals.?
2 The wire to the starter motor from the ignition key which I used for the switch ( in cabin ) on the dual battery setup does not run to the fuse box as the manual states it should . Should I leave this as well . .?
Forgive me if the questions are basic , my first foray into anything hands on auto , and auto electronics .
1
