Horn contact
ozbrumby
Horn contact
Post by ozbrumby » Mon Nov 11, 2013 8:52 pm
Is the little spring steel arm with the horn contact a separate unit from the indicator switch assembly or can it be replaced separately.
I will post in the wanted section anyway.
Peter
Post by RSR 555 » Mon Nov 11, 2013 10:13 pm
Can be removed but the parts shops (new or secondhand) sell them as a complete combo switch setup. I've seen a few people make up their own pins using a spring and a pop rivot
Post by Bantum » Mon Nov 11, 2013 10:24 pm
It can be fixed - See here for more details on ... MY & L Series Turn Indicator Fix ...
Cheers, Bantum ...
ozbrumby
Post by ozbrumby » Tue Nov 12, 2013 11:22 am
http://www.ebay.com.au/itm/EX-JAPWRECK- ... 2729860%26
Does this one fit
Bantum wrote:It can be fixed - See here for more details on ... MY & L Series Turn Indicator Fix ...
Cheers, Bantum ...
Post by RSR 555 » Tue Nov 12, 2013 11:41 am
Nope.. this and the one Bantum posted are for the early L.Series and does not suit the Brumby. The Brumby use the same one as the 1980 to 1984 MY Series combo switch which has the hazard switch on the LHS of the stork
Stumped ...
Post by Bantum » Tue Nov 12, 2013 11:57 am
Um - sorry it's not clear in this shot, but this is what it should look like :
So what exactly is broken in yours ( ozbrumby ) ?
Cheers, Bantum ...
Post by RSR 555 » Tue Nov 12, 2013 12:05 pm
Bantum wrote:So what exactly is broken in yours ?
Not mine but from Peter's original post, it appears to be the little metal tab that springs up to touch the steering wheel. This piece of copper tab allows the +ve current up to the centre of the steering wheel. I've seen these replaced with a pop rivot and spring but never tried it myself. Looking at your pic, this copper strap piece looks like it's held on with 2 philips head screws?
ozbrumby
Post by ozbrumby » Tue Nov 12, 2013 3:02 pm
The little spring steel arm with the points type contact is broken and I have no horn....some would say Viagra will fix it.
So I need the little arm held on with 2 screws as Paul said.
But my indicator arm itself is very wobbly so I thought I would just replace or have a replacement on hand as I have a feeling the base plate is broken as it is very wobbly so that sometimes you have to hold it with both hands to get off high beam as it moves so far back it fouls on the shroud.
I just didn't want to pull it apart and not have a spare assembly to work with if it is stuffed. I have some extra wiring and a LED in the shroud as well as I have the immobiliser light positioned in the shroud as well which is why I didn't want to have to pull it all out again once I pull it all apart to look at it.
Bantum wrote:Um - sorry it's not clear in this shot, but this is what it should look like :
Cheers, Bantum ...
ozbrumby
Post by ozbrumby » Tue Nov 12, 2013 3:04 pm
And thinking about it the indicators don't cancel anymore so its either moved or grooved as your thread highlights.
Great thread too by the way
Post by RSR 555 » Tue Nov 12, 2013 3:28 pm
So Peter, have I got this right? you've got something that is wobbly, doesn't indicate unless you hold onto it and you have no horn :rolleyes:
You've got my problem... old age :D
Post by Bantum » Tue Nov 12, 2013 3:57 pm
Ha - Old, Broken & Abused ... :p
You'll have to give us some photos of it ozbrumby to confirm Diagnosis ... ;)
Cheers, Bantum ...
ozbrumby
Post by ozbrumby » Tue Nov 12, 2013 6:36 pm
Yeah a Viagra will more n likely fix it right up
RSR 555 wrote:So Peter, have I got this right? you've got something that is wobbly, doesn't indicate unless you hold onto it and you have no horn :rolleyes:
Post by RSR 555 » Wed Nov 13, 2013 8:40 am
Bantum wrote:You'll have to give us some photos of it ozbrumby to confirm Diagnosis ... ;)
LOL.. you sick puppy you Bantum
ozbrumby wrote:Yeah a Viagra will more n likely fix it right up
I've heard of that stuff.. probably give me a heart attack
ozbrumby
Post by ozbrumby » Wed Nov 13, 2013 12:58 pm
I had a mate went to Honk Kong and took 1 and when it didn't work instantly he took another ....ended up in hospital
My mate fell asleep sunbaking got 2nd degree burns all over his legs as he fell asleep under an umbrella. Doctor prescribed Viagra when he asked why Viagra the doc said it will not do anything for the pain but will keep the sheets of your legs....LOL
RSR 555 wrote:LOL.. you sick puppy you Bantum
Post by RSR 555 » Wed Nov 13, 2013 7:00 pm
ozbrumby wrote:i had a mate went to honk kong and took 1 and when it didn't work instantly he took another ....ended up in hospital
my mate fell asleep sunbaking got 2nd degree burns all over his legs as he fell asleep under an umbrella. Doctor prescribed viagra when he asked why viagra the doc said it will not do anything for the pain but will keep the sheets of your legs....lol
lol
Post by El_Freddo » Fri Nov 15, 2013 11:35 pm
If your indicator stalk is wobbly I'd be checking the mounting screws. On the MY/brumby I'm sure it's held in place by the shrouds over the steering column. On the L series it's mounted to the steering column.
ozbrumby
Post by ozbrumby » Mon Nov 18, 2013 8:27 pm
I will check it out.
El_Freddo wrote:If your indicator stalk is wobbly I'd be checking the mounting screws. On the MY/brumby I'm sure it's held in place by the shrouds over the steering column. On the L series it's mounted to the steering column.
ozbrumby
Post by ozbrumby » Fri Nov 29, 2013 1:17 pm
you were right
I had a screw fall out from the bottom of the shroud and hit me in the ankle I thought where did that come from.
Then noticed the indicator stalk was even worse.
Pulled it apart last night and sure enough there are 2 screws from the bottom up near the steering wheel that screw the assembly to the shroud.One was missing and the other just fell out.
Found a coupla screws that were suitable and put em in tightened up and voila no more floppy stalk and the indicators cancel out again.
Now just have to find the little horn contact and replace it.
Peter
Post by El_Freddo » Fri Nov 29, 2013 5:20 pm
Sweet 8)
Enjoy the new cancelling indicators!
Proton mouse
Post by Proton mouse » Mon Dec 02, 2013 12:11 am
Viagra now comes as a liquid in the form of eye drops.
It makes you take a good HARD look at yourself!!
