Impreza coil pack
Posted: Thu May 09, 2013 8:07 pm
by FujiFan
Just picked up a coil pack straight of an engine for a 95 Imp.
Not sure how to test it cause im not sure of what the 3 wires designations are
So does anyone know how to check it or can direct me to a wiring diagram for engine electrical section?
Part# 22433 AA360
cheers
Posted: Thu May 09, 2013 8:12 pm
by TOONGA
FujiFan wrote:Just picked up a coil pack straight of an engine for a 95 Imp.
Part# 22433 AA360
cheers
there you go 1995 impreza electrical section
http://jdmfsm.info/Auto/Japan/Subaru/Im ... 20SECTION/
if thats not the right one then click the impreza link on the page and it will take you back to the impreza section.
Posted: Thu May 09, 2013 8:36 pm
by FujiFan
Thanks TOONGA, that helps.
Posted: Fri May 10, 2013 12:52 am
by RSR 555
From memory (as I can not get this wiring diagram) there is ignition power to one wire (I think it's yellow with a red trace) and the other 2 go back to the ignitor. The ignitor then has 2 wires going back to the ECU and one to earth
Posted: Fri May 10, 2013 11:12 am
I got a coil off an Imp 1.6 and found part number same as on an EJ20 Foz - handy trivia
