Subaru Leone RX 1987 4 plug ecu engine tach wire / rpm
Subway eat frsh
Post by Subway eat frsh » Fri Apr 12, 2013 12:12 am
I am new here on subie forums... I,ve got problem with installing "piggyback" computer to my subaru rx leone turbo 1987.. It has 4 plug ecu cable, and the problem i,ve got is that i dont know where i can get the tach/rpm signal for my piggyback. It need tach/rpm signal for working. So does the 4 plugs what goes to ecu have this tach/rpm signal wire? And if it does what wire is it ?
- Greetings Virta
Post by steptoe » Fri Apr 12, 2013 10:21 am
Couldn't you just take it from the coil. I declare i forget which side of the coil is tacho - er neg ?
Post by RSR 555 » Fri Apr 12, 2013 11:40 am
Are you using a wiring diagram to wire up the piggyback?
The factory ECU will get a RPM sense from the engine but you'll need to check against the wiring diagram.
Subway eat frsh
Post by Subway eat frsh » Fri Apr 12, 2013 5:38 pm
Hello!
Yes, i am using a wiring diagram, and i forgot to reply that i found the wire, wich leads to tach..
Greetings Virta
