Wiring Spot light to OEM Switch
Post by guyph_01 » Sun Mar 24, 2013 9:58 pm
Hi guys,
I want to wire up some spot light on the Liberty i'm building but i'd like to use the Outback Fog light Switch so it looks factory.
Now I don't understand this stupid switch. Its got 5wires
Blue W grey dots
Black W grey dots
Yellow W Blue line
2x White W Yellow line
White W grey dots
The plan is to wire the spot light to the high beam using the diagram below.
I want to wire this OEM switch at 86 and have its little pilot light light up too but how can i tell whats what with those 5 wires???
Thx
Post by RSR 555 » Mon Mar 25, 2013 3:18 am
Grab yourself a WSM with wiring diagram in it to see the fog light switch.
As for wiring the spot lights on later models, use this method...
showthread.php?t=12663&highlight=earth+switching&page=2
Post by guyph_01 » Mon Mar 25, 2013 6:10 am
RSR 555 wrote:Grab yourself a WSM with wiring diagram in it to see the fog light switch.
Where do i get that?
Post by TOONGA » Mon Mar 25, 2013 7:08 am
guyph_01 wrote:Where do i get that?
try here http://jdmfsm.info/Auto/Japan/Subaru/Legacy%20Outback/
from 1990 - 2009
WSM = work shop manual
FSM = factory service manual
Post by guyph_01 » Mon Mar 25, 2013 10:18 am
ohhh ok, Thx Jules:)
Post by RSR 555 » Mon Mar 25, 2013 3:28 pm
guyph_01 wrote:ohhh ok, Thx Jules:)
Nah that's cool Guy.. I know you meant me too :-|
Post by guyph_01 » Mon Mar 25, 2013 4:21 pm
RSR 555 wrote:Nah that's cool Guy.. I know you meant me too :-|
Lol, Yep you too Paul:)
Post by guyph_01 » Mon Mar 25, 2013 6:49 pm
Bahhh, This is a nightmare!!! I don't understand!!!! Plis it looks like the wires i have don't match...
Post by RSR 555 » Mon Mar 25, 2013 7:21 pm
Call Taza to come over
Post by Gannon » Mon Mar 25, 2013 7:22 pm
What year model/gen Outback, I have a stack of FSMs
I used a fog light switch for my spot lights,
Post by guyph_01 » Mon Mar 25, 2013 8:44 pm
It a 98 Outback AUS the first outback.
How did you do it?
Subydoug
Post by Subydoug » Tue Mar 26, 2013 9:16 am
So you want the spotlights to come on with the hibeam, but also want to be able to turn them off with the fog light? Or you want to be able to turn them on and off with the fog light, but dont want them on during lowbeam?
If you want them to come on during hibeam and be able to turn them off it should be easy. Just make sure that the current hibeam relay can cope with the extra current of the spotties. Id run a new relay anyway to isolate the circuits. Then all you need to do is break the exite line for the new relay with the fog switch. That way there is no high current wiring in the dash.
Doug
Post by RSR 555 » Tue Mar 26, 2013 4:12 pm
Updated with a better link from Gannon
guyph_01 wrote:How did you do it?
Using a multi-meter, find 2 pins that create a circuit when the switch is pressed in. If you look at the wiring diagram you'll see what the pins all do.
I hate wiring and still find this easy, so you'll have no issues with it
Post by guyph_01 » Tue Mar 26, 2013 5:50 pm
Doug
Thats the Plan but i need to figure out what wire does what on the fog light switch and how to get it to illuminate when on..
niterida
Post by niterida » Tue Mar 26, 2013 6:16 pm
WHy are you bothering with the switch - just use the fog light wires near the headlights and wire them to the spotties - thats what I did on my Outback.
Post by RSR 555 » Tue Mar 26, 2013 6:47 pm
niterida wrote:WHy are you bothering with the switch - just use the fog light wires near the headlights and wire them to the spotties - thats what I did on my Outback.
Because it's the law that your spot lights turn off when you dip your high beams.
niterida
Post by niterida » Tue Mar 26, 2013 7:08 pm
RSR 555 wrote:Because it's the law that your spot lights turn off when you dip your high beams.
yeah mine do - wired them up as per spotties with a separate relay and power from high beam then just used the fog light wires as the switched wires. Too easy :)
Although mine do have a strange anomaly where they go off with low beam but back on with park lights but I can live with that. Someone on here explained why that happens but I didn't really pay much attention 'cos it works and I'm a lazy bugger and couldn't be bothered going back and fixing it !!
Post by RSR 555 » Tue Mar 26, 2013 8:58 pm
guyph_01 wrote:Thats the Plan but i need to figure out what wire does what on the fog light switch and how to get it to illuminate when on..
I've had a quick read of the wiring diagram and come up with this...
The plug on the Fog Light Switch should be yellow in colour with 6 pinout places. Only 5 wires are used as follows
Pin#1 - Black with White trace wire connect to Red with Yellow wire from LH Headlight
Pin#2 - Yellow wire connect to Illumination Circuit (you'll need to find one from another switch closeby, should be the same coloured wires)
Pin#3 - White wire connect to pin #86 on your Spot Light Relay
Pin#4 - White with Yellow wire connect to Illumination Circuit (again you'll need to find one from another switch closeby, should be the same coloured wires)
Pin#5 - Empty spot (no wire)
Pin#6 - Yellow wire do not use
The rest just follow as per Gannon's wiring...
showpost.php?p=211409&postcount=14
Post by El_Freddo » Wed Mar 27, 2013 5:08 pm
RSR 555 wrote:Using a multi-meter, find 2 pins that create a circuit when the switch is pressed in. If you look at the wiring diagram you'll see what the pins all do.
Exactly my thoughts too! By far the easiest way to do it!
If you don't have a multi metre you'll need to sell a factory thermo fan or something for $20 or $30 from memory - get a digital unit. Dick Smith/JayCar/SCA etc will have them.
Use the Ohms setting, then start probing. When it goes to "1" then you've got a circuit. You might have to try the switch in both positions going through all the wires to find the right combination ;)
Have fun!
And won't this switch still have the fog light symbol on it??
