Xtreme_RX
Post
by Xtreme_RX » Wed Oct 19, 2005 5:38 pm
It is possible??
Or is there a problem because of the speed sensor??
I know the speed sensor is in the back of the lib dash
but can i 'trick' the control unit by using another speed sensor on the tail shaft??
Thanks in advance
![Wink :wink:](./images/smilies/icon_wink.gif)
Suby Wan Kenobi
Post
by Suby Wan Kenobi » Wed Oct 19, 2005 5:49 pm
No reason it wont work. I prepped one for my RX but ended up using one of the aftermarket ones so i had the indicator set buttons. The Liberty stuff that goes on the steering column wouldnt allow to have a neat looking finish.
I have used the lib vac pump on it though as prolonged period of boost would result in a loss of vac
jzk25
Post
by jzk25 » Wed Oct 19, 2005 6:08 pm
It can be done but if you have a carb L you will have to wire the reed switch up in the dash.
If you are going to buy a kit get a Gen 2 system, it is a whole lot better and less complex at the same time.
Xtreme_RX
Post
by Xtreme_RX » Wed Oct 19, 2005 8:22 pm
Its out of a series 1 Gx liberty, Well still have to take it out.
So Al whats involved in wiring it up??
jzk25
Post
by jzk25 » Thu Oct 20, 2005 6:17 pm
The cruise or the reed switch?
Xtreme_RX
Post
by Xtreme_RX » Sat Oct 22, 2005 10:15 am
The Cruse control, Its going to be fitted in to a MPEFI EA82T RX Turbo.
jzk25
Post
by jzk25 » Sat Oct 22, 2005 2:11 pm
It's pretty straightforward, just replicate it's wiring and switches in the L. The speed signal at the L ecu will be fine.
Xtreme_RX
Post
by Xtreme_RX » Sat Oct 22, 2005 9:31 pm
jzk25 wrote: The speed signal at the L ecu will be fine.
??? The ECU is a 3 Plug Flapper style AFM. Is there still a speed signal wire? If so which one.
Thanks
jzk25
Post
by jzk25 » Sun Oct 23, 2005 5:52 pm
Pretty sure the early ones still have a speed signal, JackSparrow is your man for the pin out location.
Suby Wan Kenobi
Post
by Suby Wan Kenobi » Sun Oct 23, 2005 8:11 pm
yeah the L series have a speed sensor wire which is pinout 22 on the ecu (smaller 2 row plug looking at the ECU it is the second one in on the top) but if you want to grab the signal from the engine bay it is on the read plug on the DS behind the shock tower, the orangey beige looking one.
Xtreme_RX
Post
by Xtreme_RX » Sun Oct 23, 2005 10:36 pm
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Thanks Dave & Al
jzk25
Post
by jzk25 » Mon Oct 24, 2005 12:21 pm
Lucky someone still loves their L series Dave.
![Laughing :lol:](./images/smilies/icon_lol.gif)
Suby Wan Kenobi
Post
by Suby Wan Kenobi » Mon Oct 24, 2005 4:06 pm
Well you have to always love the L series that was the model that is even now still learning up the Libertys on how to be tough. Not to mention the was they edumaketed the WRX on how to be so tough.
![Cool 8)](./images/smilies/icon_cool.gif)
jzk25
Post
by jzk25 » Mon Oct 24, 2005 6:26 pm
I like stories.
![Smile :)](./images/smilies/icon_smile.gif)
Suby Wan Kenobi
Post
by Suby Wan Kenobi » Tue Oct 25, 2005 6:32 pm
Generally us EA82T drivers have to keep very quiet about the perfomance as the EJ engined car owners like to feel good about thier cars
jzk25
Post
by jzk25 » Tue Oct 25, 2005 8:18 pm
*Looks around for link to 'Worst engine ever' thread*
Xtreme_RX
Post
by Xtreme_RX » Sat Nov 05, 2005 10:10 pm
Dave & Al,
Do you have a wiring diagram for the liberty cruse control?
I have a HUGE mess of wire on the floor.....
Suby Wan Kenobi
Post
by Suby Wan Kenobi » Mon Nov 07, 2005 8:54 am
Yes i do but no scanner to transfer to PC. I will see what i can do in the next day or so.
wagonist
Post
by wagonist » Sun Nov 20, 2005 7:54 pm
I'm doing this too.
But I've got an EJ20T & I'm fitting a Lib RS steering wheel & indicator stalks to a modded L steering shaft.
I've got a spare factory L Series "cruise" switch to suit a series one here.
not the steering wheel switch, but the one that sits on the top left on the right side of the steering column.
