LED Conversions ...
these look like they could be good for rear bulbs in the sudie sedans...
http://www.superbrightleds.com/moreinfo ... angle/162/
I wonder how bright they are, compared to a bulb?
and would you get white, or red?
# EA82 AWD 4EAT,
If you have them please PM me
# EA82 AWD 4EAT,
They look pretty neat but why the need for 90deg on the sedans
Well if you used the normal ones that have a lot of LED's stacked around them like a hairbrush, you would only see about 1/3 of them and I reckon it would not look very bright.
# EA82 AWD 4EAT,
# EA82 AWD 4EAT,
- Bantum
Pin LED's ...
I was also thinking of putting LED's in the dash ( pin type ) ...
Next project though ...
Nah don't. I looked into this some time ago. LEDs don't have a very nice light dispersion and your cluster will have spots where the LEDs are really bright and other spots where it'll be very dull.Bantum wrote:I was also thinking of putting LED's in the dash ( pin type ) ...
Sent from my Motorola RAZR HD
Best thing to make LED's give light in a uniform manner is to lightly rub the top and sides with fine sandpaper to make the surface opaque. They emit light much more like a normal globe at a slight expense of light output
- Bantum
More LED's ...
This is what I was thinking of in a T10 ...
It has a diffuser lens of sorts - will have to try it out & see how it looks ...
- Rodeo4jake
- Bantum
LED Switch ...
Speaking of Dash Items, I just found this neat looking switch :
It could be used for all manner of things, I'm thinking of spotlights, etc ...
Edit : Reload image ...
- Kalbarri_baru
Just waiting on new globes from HK, but I had made the mistake on my last lot of LED globes for the Indicators, Brakes, and Reverse lights, HOWEVER these globes created error which included faster flickering of indicators and the globes were not as bright as the original.
$30 poorer for the auto sparky to tell me that I needed load resistors http://www.ebay.com.au/itm/Load-Resisto ... 342&_uhb=1 .
I have since reviewed and bought on Ebay Error Free LED Globes (CANBUS) you will need to lookup CANBUS ba15s led globes on Ebay, click HERE
These are the Globes you will be looking for in most L Series.
I will post some pics and a review once they go in, I have also purchased some T10 LED wedges for my plate No lights.
Cheers WayneO.............
- Kalbarri_baru
Also my rear tailgate has two rows of 5050 smd led's that are ultrabright, I disconnected my rear windscreen wiper power and hooked up a remote control on / off with dimmer to the LED strips, this makes it practical when fishing as I can control my light situation from the beach.
- 5.jpg (40.21 KiB) Viewed 7826 times
- 4.jpg (39.5 KiB) Viewed 7824 times
- 2.jpg (25.58 KiB) Viewed 7825 times
- 1.jpg (33.62 KiB) Viewed 7827 times
I can vouch for Wayne's LEDs on his tailgate, they are bright as f**kin bright.Kalbarri_baru wrote:Also my rear tailgate has two rows of 5050 smd led's that are ultrabright, I disconnected my rear windscreen wiper power and hooked up a remote control on / off with dimmer to the LED strips, this makes it practical when fishing as I can control my light situation from the beach.
BTW.. awesome thread
- Kalbarri_baru
My T10 led wedges (Blue) arrived today I first placed them in the park light housing but they were too blue (looked ultra cool though) and then I placed them in my tailgate as number plate lights, again too blue, leaving them in would have had a flashing blue light behind me.
Looking at a light purple for the front parkers and 5050 smd white for the plate number.
Will place some pics of the blue on front and rear, BTW the blue T10 wedges are free to a good home.
- 6.jpg (20.17 KiB) Viewed 7813 times
- 5.jpg (31.49 KiB) Viewed 7814 times
- 4.jpg (32.36 KiB) Viewed 7813 times
- 2.jpg (40.49 KiB) Viewed 7814 times
- 1.jpg (53.16 KiB) Viewed 7813 times
- Kalbarri_baru
Just fitted the new (White) 5050 smd T10 wedges to the parkers and they seem ok, they have a purple tinge to them but that is what I was looking for anyway.
Bad news on the indicators, the T10 wedges are longer than the standard bulb and will not fit inside the front indicator housing, so this rules out the LED conversion on the front indicators (for now).
Will take some photos tonight of the front parkers, BTW I have just bought another 4 White 5050 smd wedges for $3.60 which comes with free postage from an Aussie seller, getting the bling without the ca ching.
Cheers WayneO
Cheers WayneO
often the cheap LEDs die quickly, not the LED itself but the internals of the holder.
you cant just plug in LEDs as indicator replacements. Youll have to wire in some resistors to stop the blinker flashing too fast.
If youre after white light id just got for a regular halogen type globe which is labelled as white. Often the globe itself is blue, but the light it puts out is very white. Narva do some good examples of this and im currently running them in my parkers in my VW.
- Kalbarri_baru
- Bantum
Update ...
Been meaning to add the wiring diagram for this ...
Note : I've added an earth to the Dome light - not shown on previous image ...
The above diagram is for the existing condition - Do note the following :
Add : I got the basic wiring diagram info from here : http://webmonkees.com/art/sub/85bratwires.jpg
Working to make this a 'wiki' page also ... If I've forgotten something or it doesn't look right, let me know ...
Cheers, Bantum ...
Edit : re-linked image - May 2021
- Stop Lamp comes off the same circuit ...
- Add : Not shown ! - The stop warning Lamp ( 57 ) is also earthed via door switch earth ...
- Goes to 'Door Ajar' indication lamps in dash before making their way to the door switches ...
- Circuit then returns to earth after the Door Switches ...
- The courtesy light can bypass the Doors via dome Switch ...
- Some of the wire colour codes I've used may not be the same as your car ...
Cheers, Bantum ...
Just bought these:
http://www.ebay.com.au/itm/2X-1157-BAY1 ... 27dac04ef8
Canbus BAY15D 21/5W LED indicator/brake globes. Best thing is its not from HK or China
Interior LEDs - SH Forester (and BK Mazda 3)
Just found the thread. Couple of years late, as usual!
The link below I posted elsewhere and may be of help to those with a SH Forester (mine's a diesel) and as an aside, a 2004 BK Mazda 3 SP23 which conveniently uses the same bulbs.
Seems to be no CANBUS interference with my Subaru.
Find the link here (2nd post if you just get to the thread) and if anyone has any ideas about spacers/reflectors to assist a couple of the bulb positions (tailgate area in particular), let me know.
To speed my installation and get a better idea of their effectiveness, I installed them at ~1am outside in winter in Canberra
The bulbs are expensive but worth it. They fit the plug receptacles to begin with and have the electronics built in. CANBUS-compatible ones are available. I've had them in both vehicles for about 8 months with no light decay, no unevenness, consistent colour, no failures (yet). No pics, due to a dodgy little auto-exposed-only camera. If it's any assistance, the first time my 2-y.o. (at the time) saw the interior light, she said "too bright!"
As far as I know, LEDs come in different quality batches (and certainly so does the electronics and workmanship). There's a reason you can get 10 of some for the price of one other.
So far, so good.
So far, so good.
Patrick
Ex- 2010 Forester Diesel
