centural locking problem
- leeton1203
i have a 95 liberty and the centural locking dosent work. fuse is good, not sure if there is a comon problem or not. i would also like to install a keyless entry unit any recomentions?
- Brumby Kid
If its mechanicle, take the door skins off and check it out.
Also I found the battery needs to be reasonably fully charged for my aftermarket system to work. You can turn the engine over but central locking is a no go.
Its Probebly that or the actuator.
Cheers Cam.
Cheers Cam.
- d_generate
Alarm can mess with it, the main control box is behind the l/h kick panel, that could be a problem but as above it could be one of many things, my remote central locking on my 98 only works about half the time.
http://www.youtube.com/watch?v=TKrsF-2JS3M![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
![Image](http://i26.photobucket.com/albums/c119/d_generate/cruise16.jpg)
Check the drivers door switch (near the window controls) is working and has power to it, also check the control module on the drivers door mechanical lock is working and has power.
