solor panels???
vidler
solor panels???
Post by vidler » Sun Apr 30, 2006 10:39 pm
just considering getting one but i dont know much... can anyone give me any suggestions? just want one to power a seperate battery to supply light when camping. have found a smallish one that puts out 12w. will this be adequate?
09 Forester XT Touring Wagon
fredsub
Post by fredsub » Sun Apr 30, 2006 11:10 pm
12W is only good enough to trickle charge a battery really, its 12W at midday brightest light ideal condition only I bet.......
I can highly recommend the flexible amorphorous type panel - 32Watt, even helped me recharge battery enough to start engine in the morning after possibly using it a bit too much the nite before.
Have got a crystalline type -solarex - wich is good, but the flexible types are far better in convenience, altho even more expensive $ per watt....
Got a small crystalline one too, 10W, got it ages ago, breaks too easily ...not worth it!
vidler
Post by vidler » Tue May 02, 2006 10:21 pm
sounds like too much stuffing around than its worth unless i wanna spend large amounts of money
Fury
Post by Fury » Tue May 02, 2006 10:37 pm
It really depends on how much you want to spend.
If you set up another SMALL battery, with a manual switch for charging from the engine ( were talking cheap setup here) and use low voltage LED units, 3 or 4, will litterally draw milli amps, and you wont need to charge. I ran my entire caravan ( in which I was living at the time) on 1 12 v battery, lighting, microwave, TV, Video, with a trickle charge solar unit in summer, and subsidised bya kmart charger (a 3 amp jobbie) during winter.
Be smart, research what you need, amperage, voltage and see what all the alternatives are. work to find out what your worst requirements will be and work backwards to meet that need - not an overkill.
It doesn't need to be complicated, or expensive.
My brother, used to have an alternitive energy business - he ran his whole house on solar - that cost him under 3K to set up - even including the backup Generator (which he built himself with an alternater)
Chris :cool:
'88 Vortex AWD turbo with "go hard" attitude -
WRX EJ20G and box , TD05 Turbo and 4.111 running gear.
5 Stud conversion (Crossbred Performance) Multi pot GT Legacy brakes and 17" rims
Plenty of plans... the plans are getting done slowly;).... getting there - NOT! ;)
