Impreza 2L gx ignition switch wiring diagram
Hi guys I am deperatley trying to re do my ignition switch in my 2000 impreza.I have seen the 2.2 digram on here but my wiring if different,any chance anyone knows where i could find one?:???:
Now-00 Impreza 00 GT Forester
Then-5xVortex's Glf Hardtop
GC (first style) or GD (bugeye) Impreza?
All ignition switches should be interchangeable, even with L series, the only difference will be the wire colours
My 1997 GC wiring diagram says that
Batt = black/yellow
Acc = red/yellow
Ign = red
Start = blue/red
2002 GD diagram says
Batt = black
Acc = yellow
Ign = green
Start = white/black
1992 BC Liberty
Batt = black/yellow
Acc = red/yellow
Ign = red
Start = blue/red
Post a pic of what you've got
Batt = black/yellow
Acc = red/yellow
Ign = red
Start = blue/red
Batt = black
Acc = yellow
Ign = green
Start = white/black
1992 BC Liberty
Batt = black/yellow
Acc = red/yellow
Ign = red
Start = blue/red
Ahh you mean ignition relay.
If you just want to replace it with another relay, it will plug straight in, they were all the same, even if the wire colours are different.
If you want to replace it with 2 bosch relays, you will need to show me the wiring diagram you have for the Gen1 BC Liberty
Where did you read about using bosch relays?
Oh yep here it is
showthread.php?t=19809&highlight=ignition+relay
Image copied from other thread.
Your Ignition relay
Just copy the diagram, terminals 1, 2 and 3 are the same as yours, and with terminal 4, yellow green instead of yellow red, terminal 5 and 6 are both black red instead of yellow
Maybe you should try to source a new replacement relay if it is giving you issues.
Send a PM to FROG, he will get you a good price on a genuine item
Your Ignition relay
So what are the problems you are having?
Damn.. pooh.. sh*t..
Just remind me again.. did you have any codes and have you cleared them recently?
yes damm alright lol ummm it said error 12 but we havent cleared it yet how do you do that btw?We have done-fuel filter,faulty lead(was tested),spark plugs,checked exhaust,cleaned air flow sensor,replaced ignition relay.
over it now all started after that dodgy fuel, coincidence i dunno :/
How does it go when accelerating at full throttle?
And dont say "vvvvrrrrrrrooooooooommmmmmmm"
Here is the issue.. sorry I missed it but they DO NOT like cleaning. They have a hot wire sensor in there and any little drop (even cleaner will leave residue) will cause issues. I would definately try one off another car. Impreza have and some Liberty have the same model/type.GTFOZZY wrote:yes damm alright lol ummm it said error 12 but we havent cleared it yet how do you do that btw?We have done-fuel filter,faulty lead(was tested),spark plugs,checked exhaust,cleaned air flow sensor,replaced ignition relay.over it now all started after that dodgy fuel, coincidence i dunno :/
Gannon wrote:How does it go when accelerating at full throttle?
OhhhGannon wrote:And dont say "vvvvrrrrrrrooooooooommmmmmmm"
