Cheers Alan
twin sealed headlight convert to H4 globe
don't know if this has been listed before as only new to the forum and Subaru's. After having a look around and giving the old girl a tub and clean under the bonnet i notice the headlights are a sealed light unit, just wondering if their is a model with the same headlights but with the bulbs
Cheers Alan
Cheers Alan
A "little wiring upgrade"? lol.sven '2' wrote:These are superior to units with bulbs.
Navara make a replacement (think they also fit a Landcruiser) which with a little wiring upgrade, will result in a very nice light output.
The wiring upgrade seems daunting when you discover the unique "positive switching" but its not too hard. You can do it yourself or buy a kit like Venom did.
Are these sealed beams halogen? I used to have an old Ford Escort with sealed beams that i replaced with Hella halogen inserts & 100/90W globes...made a huge improvement. A friend had 150W sealed beams in his Datto 1600 but I'm sure mine were at least as bright.
Ah, Dattos...those were the days hahaha
car is a 1990 brumby MV only reason for the change is one has a cracked lens and one drive light is opac looking but they worksteptoe wrote:You don't mention what car, but assuming you mean an MY. I keep some as spares and never in thirteen years 400,000km needed them! It is easier to just chuck on some driving lights hooked up through high beams with a separate switch to comply with ADRs.
Having put in high power bulbs with my wiring upgrade, I really appreciate the much better light, both on low beam & high. Driving lights are great & i will be getting some as soon as the finances allow...but they only work on high beam.
So I would happily recommend you replace them esp as you may be able to put in glass inserts which will allow you to use the high power bulbs.
- Brumby Kid
Depending on how you wire them, they can come on whenever you want.
the semi sealed beam replacements are for a landcruser
80 series fit the twin headlamp brumby
(if your not upgrading wiring use h4 lamps for all 4 the h1 units short earth to the body and high beam will come on and off with viabration or whenever you turn on the headlights)
and i think the single headlamp comes form the 100 series but not sure
