headlight problems.
Posted: Thu Jun 30, 2011 3:20 pm
by lwood
I have a 1990 brumy ute. When the headlights (outer lights) are on low beam they glow bright, but the two iner high beams glow dimly even though there not meant to be on. Could this be an earth problem or is it correct?
Posted: Thu Jun 30, 2011 4:01 pm
by d_generate
I'd say earths for sure, usually what happens with tail lights & earth is the cause
Posted: Fri Jul 01, 2011 2:41 am
I thought the brumby's were positive switched, not negatively like the L series is.
In which case I would have thought that the cause would be a positive leak to the high beam units somewhere in the system - possibly the globes in the low beam lights as I'm sure they're low/hi combo.
Posted: Sat Jul 02, 2011 6:33 pm
by mattl200
brumby's are negative switched like the MY wagons
i have had a similar problem before with h7 semi sealed inserts with metal backs where the back of the inside lights short to the body and in my case the high beam came on full whenever the headlights were turned on
