headlight problems.
lwood
headlight problems.
Post by lwood » Thu Jun 30, 2011 3:20 pm
I have a 1990 brumy ute. When the headlights (outer lights) are on low beam they glow bright, but the two iner high beams glow dimly even though there not meant to be on. Could this be an earth problem or is it correct?
d_generate
Post by d_generate » Thu Jun 30, 2011 4:01 pm
I'd say earths for sure, usually what happens with tail lights & earth is the cause
Post by El_Freddo » Fri Jul 01, 2011 2:41 am
I thought the brumby's were positive switched, not negatively like the L series is.
In which case I would have thought that the cause would be a positive leak to the high beam units somewhere in the system - possibly the globes in the low beam lights as I'm sure they're low/hi combo.
mattl200
Post by mattl200 » Sat Jul 02, 2011 6:33 pm
brumby's are negative switched like the MY wagons
i have had a similar problem before with h7 semi sealed inserts with metal backs where the back of the inside lights short to the body and in my case the high beam came on full whenever the headlights were turned on
