Where is the ECU?
Where is the ECU?
I'm about to replace the ECU in a 96 Lib GX Wagon and I can't even see it
Can anyone tell me exactly where under the dash it is? Cheers
ok
lift up the carpet on the passengers side floor up near the fire wall
you will see a steel plate bolted on the floor, the computer is under this plate
If you sit in the passengers side seat and stretch your legs straight till they hit the floor firewall section this is the location
hope this helps.......
