Waterproofing Dizzy's on EA81's
I had a bit of problem with water get in the dizzy (by water read like 5 dops but enough not to start the car). I would like a solution that doesn't look to ugly, ie rubber glove with cut off finger tips. I am open to suggestions?
"Claudia"
"Claudia"
Gasket
Maybe this is what you need to stop water ingress
Steptoe has some info on this gasket which is below
Hylton:twisted:
Hylton:twisted:
steptoe wrote:
Uploaded with ImageShack.us
And in a state you may recognise instead of the pretzl above as it came packed
Or for a quicker job - than the delivery time from Japan - a very careful application of silicone will do the same job.
Giles.
Giles.
I might see what Mr Andrew can do, aka Frog.
"Claudia"
"Claudia"
- FROG
done ordered be here tomorrow
Well actually it will be monday before i get it so technically i waited a Month!
lol!
"Claudia"
"Claudia"
- FROG
PRETZELS !!!!
See Jonno one day and CHEAP
(Posted today Matt)
(Posted today Matt)
- TOONGA
would love to see pictures of this ring gasket being installed into an EA81 dizzy as for the life of me I can't see where it would go (yeah I know between the cap and the dizzy)
my personal favourite is a liberal application of axle grease on the mating surfaces of the dizzy cap and body, then a giant dose of canola oil spay on the internals and inside of the cap
- littlewhiteute
You spray canola inside the cap?TOONGA wrote:would love to see pictures of this ring gasket being installed into an EA81 dizzy as for the life of me I can't see where it would go (yeah I know between the cap and the dizzy)
Does this prevent water condensing within the cap even though it would be conductive to HT voltage?
Gary
Gary
- FROG
yep just ordered one for the "new" camping wagonsteptoe wrote:I must have started something....
that leaves one in the warehouse
- TOONGA
the canola oil repels the water. I've never had a problem with it conducting electricity, it works the same as WD40 or RP7 but costs 1.99 at coles.littlewhiteute wrote:You spray canola inside the cap?
and in a pinch spray it on the exhaust then you can fry eggs if you are without a frypan
I just did mine, i will try and take some pics. Also does anyone know what the seal number for a EA81T? And whether you can still get them?
"Claudia"
"Claudia"
