ebay thermo fans
ebay thermo fans
I was looking on ebay at thermo fans and it looks like theres some pretty good thermo fans for a pretty decent price was just wondering if anyone has got aftermarket thermo's and how much cooler do they make your engine run
With aftermarket fans you can get different sizes and they supposed to be better than stock depending on the type
A fan will only make the engine as cool as the thermostat will let it get it's when the engine is under load that it will make a difference
Jan
Jan
- d_generate
I'm seriously thinking of putting one under my bonnet scoop to blow through the top mount and possibly get rid of some turbo heat also when I'm slugging through the soft stuff, I should have enough room since I put the 30mm Outback spacers in the front X member.
I wonder how that would go myself keep us informedd_generate wrote:I'm seriously thinking of putting one under my bonnet scoop to blow through the top mount and possibly get rid of some turbo heat also when I'm slugging through the soft stuff, I should have enough room since I put the 30mm Outback spacers in the front X member.
Jan
- d_generate
Apparently it's a popular mod on the turbo's on the bigger Nissan etc 4X4 forums with cars getting a heap more hp because of the cooler inlet temps.
