4WD light remains on when in (I believe) its in 2WD?
- SuperSonicSuperMoose
Hi, I have a '90 Brumby, and the 4WD light remains on, evern though, as far as i'm aware, the 4WD is disengaged? I have tried engaging 4wd Hi then Lo, then disengaging, but even with the shift lever hard to the floor the light still remains on, and I can feel the 4WD disengage. Is it just a dodgy switch, am I just thinking things when I think ive disengaged it and it could be a gear box problem, or what else might it be? And how can I fix it?
Thanks, Matt
Thanks, Matt
The more people I meet, the more I like my dog.
Current beast: 1990 Subaru Brumby
- TOONGA
the switch as far as I can remember lives next to the Hi / Lo lever under the plastic of the console, it is a very simple operation to gently lift the plastic surround of the Hi / Lo lever and fix the switch. watch out for the plastic as it isn't the strongest and the tabs that hold the Hi / Lo lever cover in place have a tendancy to break
I no longer have the brumby console so I can't take photos but Im sure one of the many brumby owners on the board can
- TOONGA
not a problem, the previous owner of my brumby used a hose clamp and a bit of wood to make the switch work again in my brumby. it was one of the few things he didn't try to fix with locktite superglueSuperSonicSuperMoose wrote:Ah, why thank you again TOONGA. I will try that right now, wish me luck to not break anything :-S
