Gen2 Lib CC wiring diagram
Posted: Tue Apr 27, 2010 9:12 pm
by Venom
Hey guys,
I'm trying to help someone change from a console mounted CC on/off main switch to the dash mounted on/off switch. I've found the diagram for the dash mounted switch but i can't find one for the console mounted one, anyone able to help?
Rhys
Posted: Tue Apr 27, 2010 9:17 pm
by AlpineRaven
what year liberty is it?
the early Gen 2 '94/95 wire is located right side of steering wheel.
Gen 2 Series 2 '96-98 are located under centre console.
Hope that helps.
Posted: Wed Apr 28, 2010 2:08 pm
If you've got the plug from behind the switch you could easily run it to the desired location by cutting the plug and adding a lenght of wire to the plug/switch...
Posted: Wed Apr 28, 2010 2:23 pm
by Venom
Thanks bennine but i already have the plug and the the wiring diagram for the dash mounted switch. What i need is the wiring diagram for the console mounted switch because the wires are different colours. Gen1s have the console mounted switch too but the WSM diagram is just that, diagramatic, and doesn't have individual wires and colours.
Rhys
