Light problems
Posted: Wed Mar 03, 2010 9:21 pm
by legend223
Hey guys i have a subura Lib 2000 my01 and i just replace the battery like 1 month ago and im starting to notice that the handbrake light and battery light comeon and off im using powercrank 460cca what size battery should i be using to stop this problem please help guys
Posted: Thu Mar 04, 2010 6:39 pm
by AlpineRaven
Sounds like you have alternator or earthing problem
Posted: Fri Mar 05, 2010 2:43 pm
by Alex
make sure your terminals are tight on the battery and all the connections into it are still good.
Posted: Fri Mar 05, 2010 8:11 pm
by legend223
Ok did a check on the alternator nothing wrong its charging the battery ill make sure the plugs on the battery are tight
Posted: Mon Mar 08, 2010 1:16 pm
by openflame06
See if theres any loose wires, could be that when you are driving one is being rattled enough to make the lights come on temporarily.
