Cheap Rev limiter?
- subarooster
Cheap Rev limiter?
Okayy, had a thought today. I've been looking around at rev limiters lately (ignition cut ones) and most units have come up at around $400 - $500. So it got me thinking. i wonder can i manufacture one for under $50? I had a look at the old "monsta" tacho i had that i never use and got an idea. If I hook up the tacho and use the shift light as a trigger for a changeover relay, it might just work. I was thinking of running the negative side of the coil through the (always on) pins on the relay (30 and 87A) and then when triggered it will change over to the other pin (87). This will hav to be earthed so the spike has somewhere to go, otherwise it will feedback and cause pre ignition. So set the shift light to come on at say 6000rpm and as soon as it hits that the relay will changeover, then it will change back, then changeover ect... cutting the ignition briefly. The way i see it, i think i can get it to cut at around 5 times a second to giv that lovely brap! brap! brap! sound. And because its cutting the ignition instead of the convention fuel cut, it mayy shoot small flames from the exhaust. The idea sounds a little riceyy and boy racer but i'm keen to giv it ago. Tomorrow arv i shall have a go and report back. Cheers, Tom
01' Liberty B4.
- BaronVonChickenPants
The old GTHO phase III Falcon's had a "magical silver box" that worked in a similar way, I imagine they would have been dumping a lot more raw fuel than your tiny little suby engine, but then it's only until the revs drop below the ignition cut, which shouldn't take too long.
I think the concern should be the result of dumping unburnt fuel into your cat converter, they really don't appreciate that sort of thing.
Jordan.
Jordan.
- subarooster
haha the test subject is a shagged ea82 so i'm not overly concerned on it imploding.. just curious, thats all. and the cat converter is buggered as well so all good.
01' Liberty B4.
You hoon.
I might have to come over to see this
bee r rev limiter does this. ignition cut....and almighty backfire and flames occur,,,
davo
davo
- Outback bloke
- subarooster
haha yeah, but i wanted to make it adjustable. Tried and tested yesterday and had pleasing results. but way to over the top for my liking... Sounded like a WRC car at full revs before take off but ripped it all out due to it being very gay. lol
01' Liberty B4.
Did you video it?
I wanted to see it
I wanted to see it
- discopotato03
So how high will an EA82 rev till it runs out of puff?
Surely if it can rev past 5k under load, it would have enough flow to rev much past that without any load.
Maybe ignition timing and valve bounce play their part in limiting its revving capability
- thatsgoodsquishy
I spent a couple years regularly winding mine out to redline (6 or 6.5?, cant really remember) and i thought it pulled fairly well at high revs, hence why i kept doing it:D
Mine was a red blooded super version from 85 though, dont know if the unleaded version had any changes that reduced top end power? I guess they wound the timing back a bit at least:(
I have very fond memories of my L
Ben
Current: MY 07 Outback 3L
Previous: 02 B4 Manual
Previous: 95 Liberty Wagon 'Rallye'
Previous: 85 L series Touring Wagon, Auto to Manual conversion
