Brumby alternator issue
Posted: Sun Oct 18, 2009 6:20 pm
by Tezwah
Hi all, I have what might be a dumb question for you. I have been having electrical issues with my brumby in the form of the battery going flat rapidly, i have put a known good battery in and the same thing has happened. I started the car today and removed the terminals to test what output the alternator was giving and it was reading 9 - 10 volts.. i did the same test on my l series and it tested 14.5 which sounds more like its meant to be to me. could it be possible that my alternator in the brumby is cactus and is shorting somehow and when its not running it is running the battery flat?
Posted: Sun Oct 18, 2009 7:19 pm
sounds like you found the problem and just needs some thinking....it is not enough to give your battery the correct charge. I'd say it needs new bits. Try proving it to yourself by swapping alternators between your two cars and watch the L develop same symptoms your brumby is displaying. Not shorting just not working correctly.
Posted: Sun Oct 18, 2009 7:25 pm
by Tezwah
I was trying to avoid doing that but i think your right. i shall give that a go and see what happens. Cheers
Posted: Sun Oct 18, 2009 7:45 pm
by phillatdarwin
remove the + off the battery and test the amps from the battery and the + terminal and see what amps if it is pulling more then 0.05 then your alternator is RS it will test your rectifier .
just remember do not have the key turn on so have the key is removed it will give u a good reading .
Posted: Sun Oct 18, 2009 7:55 pm
by Tezwah
I'm sorry i dont follow what you just said? also what is RS?
Posted: Sun Oct 18, 2009 8:03 pm
by Tezwah
Dont worry i think i get it now...
Posted: Mon Oct 19, 2009 6:50 am
by Tezwah
Someone has mentioned to me that some Nissan alternators fit the brumby is this true?
Posted: Mon Oct 19, 2009 6:54 am
by Tezwah
More to the point which ones would do the job?
Posted: Mon Oct 19, 2009 7:45 am
by Tezwah
How do you test if the regulator is the cause of the problem?
Posted: Tue Oct 20, 2009 12:38 pm
by Tezwah
Found that the alternator was irractically charging even getting up to 17volts at high revs and as low as 13 at low revs. It was also drawing 2.5amps out of the battery when not going so went and picked up a second hand alternator for $50 and now she runs a hell of alot better!
