I want intermittent wipers
Has any electrical genius any clue on how to add an L series or luxo MY intermittent wiper control into a non luxo Brumby? I have seen some Brumby;s and MY's with intermittent wipers. My BWumby don't and needs. I have two different looking units marked intermittent wiper from either L or MY, one has six wires, another eight.
Hella do a $195 kit the 7010, I am looking more cheap and cheerful than that.I bought one about quarter of a century ago for about $30. It had clear instructions on how to determine what sort of electrical system was in use in your car.
It needed to tap into the earth return wire of the car wiper system, the low speed circuit and had adjustable (dwell) knob that was also its on/off and would only work once wipers were on.
Anyone know how to wire up?
Can you provide some photos of the units that you have? Also, do you have a spare wiper switch? I want intermittent wipers too - and I'd like to incorporate it into the wiper switch itself (replace the present three position switch with a similar-sized four position switch). I'm not after variable dwell - I just want one speed. That circuit is simple to make, and I'll look at it at the end of the month.
Ewan
Ewan
other thing you could install variable speed control wiper in.
- discopotato03
OK, two years and four months later ....
I can provide pics ....soon
Uploaded with ImageShack.us
and maybe close this post thread and use newer one >>>>
showthread.php?t=21302
If you have a wiring diagram of the MY wiper system, i'll show you how to add the l series intermittent thingo
That'll be sweet! I need to nut out the intermittent wipers on Sunnie the Brumby - he's got them wired in by someone like ourselves, but I need to work out what they've done to get them to work again!Gannon wrote:If you have a wiring diagram of the MY wiper system, i'll show you how to add the l series intermittent thingo
Good times, at least it's going to be...
Well yeah the fuse link box is what I'm after, but dont think I wouldnt have replied to this thread if I wasnt in need of one. But I will need somebody to post a diagram or 2, even if its from a Gregories or Haynes manual.
