hey guys its a long story but i have put a ea81 into my '92 Lseries 4wd, i changed the distributor for a electric (2wd Lseries dist) instead of the points ea81 dist. i was going to use the 4wd Lseries dist but i couldn't remove the pin in the drive shaft to change the lower drive so i used the 2wd one instead.
what should i do with the coil now. i have wired the dist back into the Lseries coil and had the car running but im not sure if the dist and coil should be used together?
can i run the dist to a coil with out a resistor (eg Gt40) or should i just run it with the Lseries coil if its not going to damage anything??
cheers brenton
which coil for a 2wd L series distributor
pretty sure you can run the gt40t with no resistor if your using the electronic dissy
the coil has to be 12 rated though
