convert MY coil location from RHS to LHS
Posted: Sun Feb 08, 2009 11:13 am
With my intended swap into my Brumby of EA82T I am aware that the ignition coil needs to be shifted from RHS strut tower to LHS strut tower as the dizzy will then be close by on the EA82. Would not want to risk a coil lead reach from its original position, that would be asking for trouble IF you could get one that long.
Also looks good option to shift battery from RHS to LHS as well
So, I am curious as to what others have done in the past in the EA82 into MY conversion in regards to coil.
I was thinking of setting up some insulated terminals at original location and running new wire to new location. The old location being the terminating point for all coil wires and just one wire each for pos and neg to run to new coil
Or have others just extended and rerouted wires across.
I'd appreciate your comment and share any blunders you have encountered trying this little task
Jonno
Jonno
