Where's the damn fuse?
Posted: Wed Jan 28, 2009 8:18 pm
by Battlewagon
The cicarette lighter and electric mirrors have just died in my L-tourer. All the fuses in the fuse holder are OK, tested good with multimeter. If I apply power to the lighter socket, the mirrors work again. I'm assuming that there's a fusible link blown somewhere, but where??? :confused:
Posted: Wed Jan 28, 2009 9:55 pm
by fredsub
AFAIK the only fusible links are next to the battery.
How did you test the fuses? remove from fuse tester and test with ohm range?
My preference is using a test lamp, on the fuses in the fuse holder, test lamp puts a load on the circuit tested, thus is a better tester than a multimeter.
But I would guess you have a broken wire.
Posted: Fri Jan 30, 2009 12:46 am
it is not always the power side of things to stuff up - check the earths too. Found this in an RX ----7 indicator wire - corroded, driving me mate nuts as to why it did not glow but he had power and used a different earth in his test.
Posted: Fri Jan 30, 2009 1:31 am
by Alex
my wagon did this too...but then came good after a while. i know its no help, but just letting ya know youre not the only one with this problem!
