Map Lights
Map Lights
Has anyone fitted map lights to your MY Subaru if you did how did you do it?
- SUBIIE
good question.
what car are you doing this too?
i have a map light assembly from a s1 g2 liberty that i want to fit up to my brumby, but i cant be arsed at the moment with the hassel.
cheers
cheers
The L series map light is crap. Get a liberty one, they are heaps better
Get Gen 2 Liberty ones.. they're good... i USE them all the time and always annoys me when i go other ppl's cars!!
cheers
cheers
- maxxair
i fitted the L tourer lights to the section of roof directly behind thee windscreen. (it has ~30-40mm holes in it) i cut a section between 2 holes, made a bit of a tab for on one end of the light assembely, slid this into the now butchered hole from ( ) ( ) to (____) <sorta get this?
then screwed the other end to the tin. i also modded the wiring so both lights turn on with one switch and the other to do the rear cabin light.
