Changing Door Lock actuator control
Posted: Sun Jan 04, 2009 4:20 pm
I'm trying to have a go at changing some behavior of the door locks,
in a '98 OBW
hoping for as simple as changing over left and right doors,
you see I hate the fact that ALL locks unlock, when unlocking the driver door, but that does not happen when unlocking the passenger door.
So I'm trying to find the control module.....
I've removed the driver side kick panel, on the side, and under instrument cluster. A wrap of wires is going up there.....
Looks to be a BIG job removing the instrument cluster or access up there....
anyone familiar with this area ? the wiring is very neat and wrapped, which conversely makes it damn hard to follow or hopefully modify somewhat:(
Is the control module in fact up there?
should the ECU be up there too, I can't see it.....
I do have a Liberty 1998-2003 pdf, it includes Outback for reference.....
its not as helpful as it could be:(
Also want to power the ACC (Cig lighter/accessories socket, front and rear) via a toggle switch....
I thought L series wiring wasn't great, it was hell simpler though.......
in a '98 OBW
