Stock 3 Plug Ecu mods
Posted: Sun Jan 29, 2006 6:43 pm
by AllanMajor
hi guys is there anybody out there that has any idea on modifying the stock 3 plug ecu for ea82ts as to run bigger squirters and more boost.
i dont want to go aftermarket ecu if i dont have to.
Posted: Sun Jan 29, 2006 10:44 pm
by Suby Wan Kenobi
How much more boost you want? Without touching the ECU you can run it on about 15psi before you have clutch slip issues.
Ecu
Posted: Mon Jan 30, 2006 6:39 pm
by AllanMajor
its not nescessarily the boost level im concerned at its the injector driving and sizing.
Im not wanting to lean it out, or do it any harm. if its not a doable option ill look into the fuel only aftermarket ecu and do a build on it, forgies, camshafts, headwork all that jazz, or ill go a full fuel,ignition ecu, all depends on money and time.
