Realigning a 88 brumby's steering wheel...
Posted: Sun May 18, 2008 10:26 pm
by callum
G'day guys, I guess this would be the best forum to put this in?
Have any of you guys removed and realigned the steering wheel in a 1988 brumby? It's my first car and the only problem is that it's slightly to the left when the wheels are straight - it's not a wheel allignment issue.
Is it difficult to remove and replace? I can't see it taking more than 10 minutes, but is there anything important I should watch out for?
Cheers.
Posted: Sun May 18, 2008 10:44 pm
by mattl200
its easy to remove the horn button cover should pull off or clip off depends on model and undo the nut the wheel might come loose by just pulling on it
if not give the shaft a whack with a hammer (with the nut on the end otherwise youl burr the thread and the nut wont go back on)
don't smack it too hard though
Posted: Sun May 18, 2008 10:53 pm
by callum
excellent, i figured it would just be an easy unbolt job...
thanks mate!
Posted: Mon May 19, 2008 8:28 am
by Suby Roo
Or another way to do it is to unbolt the steering arm from under the bonnet and turn it till its straight again, not sure how easy this is, just thought it may be easier...
Posted: Mon May 19, 2008 8:57 am
by Prunes
I did it by taking the steering wheel off but found it was a pain to get it quite right so I undid the nut, then drove the car slow pulled the wheel off and put it back on so much easier, altho probabily a little dangerous
Posted: Wed May 28, 2008 11:43 am
Prunes wrote:I did it by taking the steering wheel off but found it was a pain to get it quite right so I undid the nut, then drove the car slow pulled the wheel off and put it back on so much easier, altho probabily a little dangerous
I wouldn't worry about that, I've heard of professional panel beaters and the like doing the same thing - but on the freeway! A little insane for my liking...
