Realigning a 88 brumby's steering wheel...
G'day guys, I guess this would be the best forum to put this in?
Have any of you guys removed and realigned the steering wheel in a 1988 brumby? It's my first car and the only problem is that it's slightly to the left when the wheels are straight - it's not a wheel allignment issue.
Is it difficult to remove and replace? I can't see it taking more than 10 minutes, but is there anything important I should watch out for?
Cheers.
Cheers.
its easy to remove the horn button cover should pull off or clip off depends on model and undo the nut the wheel might come loose by just pulling on it
if not give the shaft a whack with a hammer (with the nut on the end otherwise youl burr the thread and the nut wont go back on)
don't smack it too hard though
I did it by taking the steering wheel off but found it was a pain to get it quite right so I undid the nut, then drove the car slow pulled the wheel off and put it back on so much easier, altho probabily a little dangerous
2002 Impreza GX Hatch: Dents, Scratches, Missing inside wheel arch, Barely attached front bumper.
1983 Brumby: Currently being rebuilt.
I wouldn't worry about that, I've heard of professional panel beaters and the like doing the same thing - but on the freeway! A little insane for my liking...Prunes wrote:I did it by taking the steering wheel off but found it was a pain to get it quite right so I undid the nut, then drove the car slow pulled the wheel off and put it back on so much easier, altho probabily a little dangerous
