Knock Sensor info
4ca
Knock Sensor info
Post by 4ca » Fri Dec 30, 2005 3:54 pm
Hi guys,
What sort of signal is given by the knock sensor....? Is it a constant voltage? How does the signal change when it senses a ping?
Can I trick the ECU into thinking there is a knock sensor connected....(I know its not advised etc, just need the info)
Thanks in advance
Paul
fredsub
Post by fredsub » Fri Dec 30, 2005 10:58 pm
they are normally a capacitive microphone type of device, could put a 2nF capacitor across the leads, but I would expect that the ECU should normally adjust to it not being there if disconnected?
but what engine is this on?
4ca
Post by 4ca » Sat Dec 31, 2005 11:07 pm
Sorry mate, should of mentioned that the engine is an EJ22 from a 96 lib.
How does the ECU interpret the 2nF capacitor? I basically have no idea but am keenly interested in how this works.
Thanks
fredsub
Post by fredsub » Sun Jan 01, 2006 7:40 am
I really don't think you need to 2nf cap, as the knock signal is AC, if you simply disconnect, the ECU's knock sensor won't hear anything :wink:
Is any fault code occuring with it disconnected? maybe the ECU can do a smart check, like check for any signal wilst engine is running.....if it does that, how to get around that? maybe a signal generator...but now its probably getting too complicated.....
4ca
Post by 4ca » Sun Jan 01, 2006 11:14 pm
Hmmmm....
Outback bloke
Post by Outback bloke » Mon Jan 02, 2006 7:59 am
They do show a fault code with them disconnected. It is possible to simply mount them some where further away from the block but still on the engine.
