temp guage beating with music
hi all...
ive had all sorts of probs with my temp guage, today i was pumping the **ck out of my stereo..checked the temp guage and it was beating with the music..moving about 3-4mm in total...surely the current drawn from my amps cant effect the temp guage??
NOTE--i have chopped through the wiring loom with the fan before(the temp guage was moving with the revvs like a tacho!) but ive since fixed it obviously!..
any ideas?
cheers
any ideas?
cheers
- Suby Wan Kenobi
ok thanks...i had the same problem with my headlights a few months back...seriously bad dimming...went out and bought a bosch gold battery..solved the problem a littlebit...
i find it weird that its only started doing it now, and its quite bad..
I would like to see how u have repaired your wiring since the fan chopped it... odd u begin to have these problems with it since then. Sounds like an earthing problem to me.
Dave
Dave
yer..i might pull the wiring loom out and check all the connections...its probably got some mud in there making some suss stuff happen..
dave, trust me you dont wanna see my "electrical" work..youll have a heart attack LOL..i did solder them though!.
Remember there is that small earth strap just under where the spare wheel goes which was too short after the lift kit install. Might be an idea to extend that and reconnect it.
EZ30 L series - Monsterwagon
- Fury
I would also check the earth, or re earth your dash cluster. If you have had more than one guage do this in the past, sounds like a weak link in the loom somewhere, and the dash is a place which is most forgotten.
Chris
'88 Vortex AWD turbo with "go hard" attitude -
WRX EJ20G and box , TD05 Turbo and 4.111 running gear.
5 Stud conversion (Crossbred Performance) Multi pot GT Legacy brakes and 17" rims
Plenty of plans... the plans are getting done slowly;).... getting there - NOT!
so i was driving home today...temp went up to 3/4...
i thought i'd try turning he headlights off...went back down to about 1/4 where it should be..WTF...i checked over the loom where i had chopped it, and it all seemed sweet...???
Have u been fucking about under the dash??
Dave
Dave
negative ghostrider....LOL
nar only to run the cables for the UHF through to the engine bay...
umm..i hooked that earth back up...just went for a drive with the aircon on full belt, stereo thumping and spotties..didnt even go over 1/3rd temp...it isnt very cold tonight either...its abit queer!...
meh, stick with the ricer effect! Beat sensitive temp gauge!!! I love it never know matt may buy it from ya
Hunter S. Thompson
Hunter S. Thompson
AAHAHAHAHHAHAHHAHAA
:D
dave
dave
