fuel pump wiring
stamp_licker
fuel pump wiring
Post by stamp_licker » Sat Sep 30, 2006 6:41 am
i'll be using the fuel pump already in the tourer when i fit the ej.the question is i've got a short bit of wire on the fuel pump relay for the ej and i've heard the ea fuel pump wire is sheilded .How do i wire it up/connect?
Building a hardcore postie:D
Outback bloke
Post by Outback bloke » Sat Sep 30, 2006 6:56 am
Is the short bit you have the black with red trace? If so then you simply connect it to the main wire for the fuel pump. Black with white trace I think it is. Have a good look though as there is two wires of the same colour coming from the back.
stamp_licker
Post by stamp_licker » Sat Sep 30, 2006 7:11 am
yep black/red (ej) .Thanks
daza
Post by daza » Sat Sep 30, 2006 8:19 am
or just leave the tourer wire unconnected and run a new wire from the Bl/red to the pump.
Daza.
:D
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sat Sep 30, 2006 12:53 pm
With the EJ you can get away with just having the one power wire going to the pump and run the Earth of the pump to the body however you will get a better result running it to the battery.
The long road ahead
