ECU Re-Location ...
ECU Re-Location ...
Post by Bantum » Wed Feb 05, 2025 4:59 pm
Been meaning to re-post this - If you have a Forester SG9 or similar the following mod is a good / cheap idea :
https://www.youtube.com/watch?v=KwwMJEiybb4
The stock location for most Forester ECU's ( except 2.0 SF models ) is under a steel panel in the passenger's footwell. This is easily accessed by popping off the sill kick panel and pulling up the carpet a bit.
Then you just undo a couple of bolts and the ECU comes out. Before unplugging it I'd recommend disconnecting the battery.
To remove the glovebox, simply open it, empty out your stuff and undo all the screws. It'll pretty much fall off then.
You could try & fit the ECU behind the glovebox but there just isn't enough space. The simplest fix is to make a cut out in back of compartment - procede to prize off the owner's manual holder, mark out approx location of ECU and cut a suitable rectangular hole in the back of the glovebox for the rear of the ECU to poke through.
Mount the ECU by marking through the holes of ECU fixing plate & drill holes - bolt / screw / Zip tie to top of box.
Can refit the shelf if your inclined ...
One thing you will need to do ( if your car has cruise control ) is undo the two bolts holding the module on and let it fall down - this is necessary to re-route the ECU cabling. You can then cable tie it back up under the dash, adjacent to the ECU wiring bundle.
Basically, this mod will stop you drowning your ECU if you get water in the car ( up to a certain level ) - it increases the wading depth by around 20cm ( airbag module is under stereo ).
Notes : Most of the above info has been extracted from this site : https://www.offroadsubarus.com/threads/5920/
Might come back & edit / add to later ...
Cheers, Bantum ...
Re: ECU Re-Location ...
Post by Bantum » Wed Feb 05, 2025 5:03 pm
One query that I do have is - Where the glove box light is ? ( haven't found it yet ) ...
Cheers, Bantum ...
Post by El_Freddo » Wed Feb 05, 2025 9:01 pm
I think Trump is yet to sign the executive order that reveals this information :mrgreen:
That mod is a must do - for just about all Subaru models, especially if you live in a flood prone zone - could be what saves your vehicle.
I believe Subaru relocated the ECU from the second Gen Liberty, unsure about the Imprezas.
Good write up Bantum! Seems easy enough. I still find photos and a write up far better than sifting through the YouTube videos.
Subyroo
Post by Subyroo » Thu Feb 06, 2025 12:43 pm
I still find far better than sifting through the YouTube videos.
Or trying to find photos and a write up on Social Media, ie. Facebook - Tik Tok - Instagram - Twitter etc. :evil: :evil: :evil: :evil:
Post by Bantum » Thu Mar 26, 2026 4:00 am
I was going to attempt this re-location whilst I'm in the process of trying to replace the cabin Air filter & find the pesky glove box light - Am yet to tackle this, so will report back when I get round to implementing ... :oops:
Ciao, Bantum ...
