hi guys
As the title suggests, I recently replaced the alternator on my '87 EA81 Brumby and I could swear the car is running better now. It was a like-for-like used replacement from an MY wagon. It was the voltage regulator that was faulty on the old one.
Am I just imagining this or is there any reason behind it?
Just thought I'd throw it out there for discussion.
David D
Improvement after replacing alternator
- TOONGA
If you replace a faulty alternator, which wasn't providing the right charged as you have stated, then it is very probable that your ignition system (coil, distributor and ignition module) will be receiving the right voltage and these electronics will be delivering the proper spark to the spark plugs causing your engine to run better. As well all of your other electrics will work better.
