This current project B3 is getting a slower approach, and as such, more thought going into it. To power up everything extra on the IGN ON circuit am doing a new supply wire from the battery to this fuse protected relay
switching for relay will come off a sole wire from the IGN section of the factory fuse box.
Chosen fattest rated wire I can slip two inside a not preferred crimp connector from Jaycar (preferred are Utilux H953 crimp with Tool No. 61) I strip off the insulator and crimp them with No. 61, then heat shrink cover them. Think I have done one of these blade fuse blocks by drilling hole larger in spade and soldering a wire right through the supply side. Thought I'd try these loops.They all tuck in towards the kick panel, well away from accelerator foot, I hope.
Any pedants have a better fuse box, or proper bridging connectors within reasonable cost ?
There is not an awful lot of room under the Brumby dash for things - except chaos wiring
