Flasher unit location + photo (L-series)
SuBaRiNo
Post by SuBaRiNo » Fri Dec 29, 2006 2:02 am
Can i bother one of u fine gentlemen for a location and photo of a L series indicator flasher unit.
I realise this is an easy thing to find when the unit is working (search for the clicking unit) but when they are not then it is a bit of a treasure hunt.
I have no idea what this unit is meant to look like... hence needing a photo.
Thanks in advance
Dave
Xtreme_RX
Post by Xtreme_RX » Fri Dec 29, 2006 8:15 am
What the indicator flasher?
Its actually part of the indicator stick assembly on the steering hub....
http://www.subiparts.com.au
0438 887 746
waggaclint
Post by waggaclint » Fri Dec 29, 2006 9:16 am
its up under the dash on the right side just next to steering coloum its hard to get apic of it ill have a look l8ter...
2011 Forester X
SuBaRiNo
Post by SuBaRiNo » Fri Dec 29, 2006 10:25 am
Yeah indcator flasher sorry. It's starting to sound like there is a different style flasher unit depending on the year L series....
If it is built into the indicator stick assembly then would that mean u have to replace that entire assembly to change the flasher??
Dave
waggaclint
Post by waggaclint » Fri Dec 29, 2006 11:36 am
nah i wouldnt think it would built in mines seperate hey right up under the dash....(like just behind the mirror switch sort of)...ive never seen one one built in on any car hey...
you should see 3 relays like these up behind the fuse block the flasher can (or relay) sits on top of these my flasher can has mitsubi writen on it and its black and square shape it has a screw holding it in place...looks a bit of prick to get out..
2011 Forester X
Xtreme_RX
Post by Xtreme_RX » Fri Dec 29, 2006 12:17 pm
The early models of 'L' Series (single stalk) Models have flasher inbuilt in to the indicator stalk.
0438 887 746
SuBaRiNo
Post by SuBaRiNo » Fri Dec 29, 2006 7:49 pm
Thanks heaps clint.... So if it is the one built into the stalk then the wntire stalk would have to be replaced right??
Dave
waggaclint
Post by waggaclint » Sat Dec 30, 2006 10:47 am
it sound like it hey.....
2011 Forester X
BlackMale
Post by BlackMale » Tue Jan 02, 2007 10:59 am
Now to make it even MORE complex… The pic attached (Thanks waggaclint) is the 3rd different indicator flasher unit I have seen for an L series in the last week. The RX has only 1 of those cylinder units, the touring wagon has a double unit (they are connected) and this pic has 3.
And we say that Subaru’s are easy to work on LOL
(PS thats for getting this up for me Dave).
SuBaRiNo
Post by SuBaRiNo » Tue Jan 02, 2007 6:44 pm
Clint said it's on top of them canisters (relays) they are not the actual flasher unit.
Dave
waggaclint
Post by waggaclint » Tue Jan 02, 2007 7:54 pm
yeah thats right dave it sits ontop or above those relays its (black and square shaped) if thats any help boys...
2011 Forester X
BlackMale
Post by BlackMale » Wed Jan 03, 2007 9:52 am
So are you saying that its the relay that needs replacing not the actual small cylinders (as pictured)?
waggaclint
Post by waggaclint » Wed Jan 03, 2007 10:28 pm
yep thats right it sits just above (the small silver cylinders.......) black in colour...the one in my car has MITSUBI written on it in white writing if that helps...
2011 Forester X
BlackMale
Post by BlackMale » Thu Jan 04, 2007 9:49 am
Nope no help ;-) The flasher unit in the wagon was berried up under the dash and it was a struggle just to get it out. I fear going higher will cause me much frustration and possible nose bleeding n dizzy spells.
Thanks I may pull it apart again on the wkd.
subanator
Post by subanator » Thu Jan 04, 2007 11:34 pm
Good those L Series dash's hey, after remember getting stuck into that one of that wreck at your place.......LOL
Still yet to do mine, something to to with post-traumatic stress or something????????
Dann
Post by Dann » Wed Feb 20, 2013 8:51 pm
just bringing up a past thread here with the flasher unit mine recently went when escorting a mate being towed at night, my hazard lights and indicators arent working so i'm guessing this should be the problem??? does the unit look like this... pic
Dann
Looking for:
- LSD diff
Post by RSR 555 » Thu Feb 21, 2013 12:11 am
Dann wrote:just bringing up a past thread here with the flasher unit mine recently went when escorting a mate being towed at night, my hazard lights and indicators arent working so i'm guessing this should be the problem??? does the unit look like this... pic
Nope. This is either the A/C Rev counter or the Wiper Control Unit
The Flasher Unit should be a round silver looking unit
Post by steptoe » Thu Feb 21, 2013 7:13 am
Not the wiper control unit, they have been grey boxes so far - that unit is something like the stop the electric fuel pump in case of an accident - about 350 bucks for a new one.
Dann, can you tel us year model or make date of your L, maybe even a pic of the indicators at the column. Er, you have checked fuses ?
Dann
Post by Dann » Thu Feb 21, 2013 6:25 pm
yeah it's a 1992 l series standard one built- Jan 1992 on a Wednesday... haha jokes but the Jan 1992 part is right, and yes I've checked all fuses, can somone post a photo of the exact relay of the flasher unit,cause i thought it would be the silver canasters too but this thread says otherwise, anyway I put the car in test mode and one at a time swapped all the relays around( only the same type ones) with one that was working and all of them worked, unless the unit is tucked right up under the dash?
Dann
Looking for:
- LSD diff
tambox
Post by tambox » Thu Feb 21, 2013 7:26 pm
Hark ye all, when all faith is lost, read the 1990 bible:D
A 3 wire plug on the LHS of the steering column.
L serious, still.
