Subaru syncro
tony_de_whitt
Subaru syncro
Post by tony_de_whitt » Mon Dec 17, 2012 12:30 am
Hello people.
Having recently installed an ej22 into my VW syncro I'm currently having problems.
Problem being lumpy and bumpy and spluttering in the low rev range. Once up to a certain revs it picks up well.
I've tried many things so far but I'm running out of ideas.
I'm about to change my O2 (lambda sensor) I've bought a Bosch universal one which was recommended to me as a good alternative to oem. And a lot cheaper.
Anyway my question is
On my wiring loom connector I have red black and white wires going into the connector terminal.
On the end of my new bosch sensor I have a black and 2 whites.
Would anyone know which goes to which?
And
I need to lengthen the wires to enable me to plug them together, do I need to use a certain grade of wire etc?
Any info greatly appreciated
Anthony
Post by steptoe » Mon Dec 17, 2012 7:22 am
Likely to help if you can ID the ECU in use, and/or what you got the donor bits from....first
Post by steptoe » Mon Dec 17, 2012 7:23 am
oh, and photos please :)
tony_de_whitt
Post by tony_de_whitt » Mon Dec 17, 2012 7:48 am
Ha ha.
Yes I'm sure that info would help a lot.
Sorry
Will get the info later and put some pics up aswell
Cheers ant
tony_de_whitt
Pictures
Post by tony_de_whitt » Mon Dec 17, 2012 8:17 am
Trying pics from phone
tony_de_whitt
Pictures
Post by tony_de_whitt » Mon Dec 17, 2012 9:55 am
tony_de_whitt
Post by tony_de_whitt » Mon Dec 17, 2012 10:14 am
So my question is
Which of the 3 wires
Red black and white is the live? Which I will connect to the live on my new sensor.
And what do I do with the other 2?
Post by steptoe » Mon Dec 17, 2012 10:28 am
Gannon was good on his O2 sensor going from one wire to four wire ...wait until h chimes in.....
Post by Gannon » Mon Dec 17, 2012 10:50 am
On the loom, red and black are the heater supply and the white is the signal.
On the sensor, the 2 whites are the heater supply, connect them to the black and red of the loom, not polarity sensitive, the black is the sensor wire, connect it to the white on the loom.
tony_de_whitt
Fixed
Post by tony_de_whitt » Mon Dec 17, 2012 10:44 pm
Thankyou very mucho for the info
Van is now running perfectly again.
Ant
Post by NachaLuva » Tue Dec 18, 2012 10:43 am
Gannon wrote:On the loom, red and black are the heater supply and the white is the signal.
Gannon to the rescue again...goodonya mate :mrgreen:
How much was the Bosch replacement? I may need to replace mine as I'm not getting the economy I should plus there's noticeable missing at ~2200rpm :(
Post by AlpineRaven » Tue Dec 18, 2012 11:08 am
tony_de_whitt wrote:
G'day,
Im interested to look at more photos of it, i love the brackets and supports for the engine & muffler.
Would the timing belt cover cope ok with the muffler there or you have heat resistance?
Post by NachaLuva » Tue Dec 18, 2012 11:46 am
Yeah great install isnt it.
I wonder if a SS heat shield might be in order...
Post by Bantum » Tue Dec 18, 2012 1:14 pm
Do you have plans for a Sump Guard ? looks a bit low to me ...
