ID this plz from 89 wagL or 87 Vortex
Post by steptoe » Sun Mar 25, 2012 11:54 am
Does anyone know what this is
Uploaded with ImageShack.us, its function etc ?
Found it on my 89 mpfi wagon I wrecked, think the Vortex also has one in same place RHS strut tower at the front, inside is a white ceramic housing like a coils resistor
Post by RSR 555 » Sun Mar 25, 2012 6:28 pm
Resistor.. check wiring loom for details of what it connects to. I think it is for the coil??
LT65
Post by LT65 » Sun Mar 25, 2012 6:55 pm
If its from a MPFI would take a good guess at it being the dropping resistor for the injectors.
___________________
Lionel.
91 Brumby EA82 MPFI
09 Cobra replica 6.0l chev
Post by steptoe » Sun Mar 25, 2012 8:27 pm
Hmm, coil is LHS this is far right ..... resistor sounds good to me :) need wiring diagram or study the parts manual
spambo
Post by spambo » Sun Mar 25, 2012 9:32 pm
yep dropping resistor for the injectors 100%
Post by El_Freddo » Sun Mar 25, 2012 10:47 pm
The unused clip for a relay or solenoid is for the turbo models...
All MPFI have this thingy what ever it is, I've never really looked into it too far.
Post by RSR 555 » Sun Mar 25, 2012 10:59 pm
I'm going with dropping resistor for the injectors.. makes me wonder if they have the same in the EJ.. can't remember seeing one :-?
Post by Gannon » Mon Mar 26, 2012 5:20 am
Yeah yas have pretty much hit the nail on the head, its the dropping resistor for the injectors because they are low impedance injectors (2 - 3 ohms). The clip on the end holds the boost sensor for the turbo light on the dash.
EJ injectors and pretty much most cars made since around 1990 have high impedance injectors (12 - 14 ohms). Interestingly, the XT6 had high impedance injectrors
nncoolg
Post by nncoolg » Mon Mar 26, 2012 6:22 am
How did the series 1 EA82's get around this? were they also high impedence injectors?
# EA82 AWD 4EAT,
Post by steptoe » Mon Mar 26, 2012 8:05 am
Yeah , could be a good explain. My 85 made, 87 compliance plated GLTA does not have one so injectors not interchangeable ???
Post by Gannon » Mon Mar 26, 2012 6:05 pm
Mmmm interesting.
Its possible that 85-86 ECU's used high current driver transistors, and in 87, they decided it was more cost effective to use smaller transistors and a resistor
Hey Jono, can you measure the resistance of your 85/86 injectors, I have some 88 injectors I'll measure
nncoolg
Post by nncoolg » Mon Mar 26, 2012 8:01 pm
parts catalog shows same injectors, well 3 different types, but used all through the year range.
Must have been sorted out with the ECU
Gannon, I have an MY99 WRX down pipe, did you want it for the flanges or the cat?
# EA82 AWD 4EAT,
Post by Gannon » Mon Mar 26, 2012 8:23 pm
That is just a thumbnail image, its too small to be legible. Can you repost the original?
I want it for the whole pipe, because just for now, it will join the turbo to the mid pipe I have with the least amount of fuss.
Is it with you or at your dads house? I spotted a vac articulator off a gearbox in his shed and I will take it off your/his hands if its cheap enough as well.
Post by steptoe » Tue Mar 27, 2012 8:09 am
Gannon, to measure would be a multi meter set on low ohms and just terminals across any injector pins in or out of car eh ?
Post by Gannon » Tue Mar 27, 2012 4:51 pm
Yeah low setting, usually 200 ohms. Yeah just test across these terminals
