Engine bay wiring
mattneggar
Engine bay wiring
Post by mattneggar » Sat Mar 17, 2012 4:28 pm
I have hooked up all my wiring apart from a wire that i cannot figure where it goes. This wire is an earth wire on the drivers side that is near the brake booster and a plug in about the middle of the car if anyone has an idea where it goes be greatly appreciated
Post by El_Freddo » Sat Mar 17, 2012 4:35 pm
G'day Matt,
If you could tell us more about your subi - make, model year etc we might be able to help you much easily. At the moment your subi could be anything with the six star logo!
And if you've got a photo even better ;)
Post by RSR 555 » Sun Mar 18, 2012 1:26 am
I'm going out on a limb here (as pics would really help) but I'm goig to say the earth wire is an earth and needs to be bolted to the main body of the car and the plug could be from the brake fluid reservior.
Please send pics to confirm
mattneggar
Post by mattneggar » Sun Mar 18, 2012 8:12 am
Its an 1997 subaru impreza RX with an EJ20 and 5 speed transmission.The wire is an earth wire which is alone above the gearbox about halfway across the whole car
Post by El_Freddo » Sun Mar 18, 2012 11:49 am
mattneggar wrote:Its an 1997 subaru impreza RX with an EJ20 and 5 speed transmission.The wire is an earth wire which is alone above the gearbox about halfway across the whole car
I'm guessing it's hanging from the body of the vehicle? To me it sounds like it might need to be connected to the gearbox - have you had this out?
Not that it's really important, subaru were obviously being over cautious with their earthing - I've not had mine connected for a few years now due to the lift kit and the fact that I've not been bothered to replace the mounting clip on the end of the wire... This wire on my L series just mounts to the body, it's not integrated into the loom.
If that's not the one let us know.
mattneggar
Post by mattneggar » Sun Mar 18, 2012 1:04 pm
Yes that is correct I had the engine and gearbox out due to a selector problem all fixed now that bit. But yes that is the wire.
Post by El_Freddo » Sun Mar 18, 2012 1:09 pm
mattneggar wrote:Yes that is correct I had the engine and gearbox out due to a selector problem all fixed now that bit. But yes that is the wire.
Sweet. Just bolt it to something on the gearbox that it reaches and you'll be sorted ;)
Glad it was an easy one!
mattneggar
Post by mattneggar » Sun Mar 18, 2012 5:03 pm
mattneggar
Post by mattneggar » Mon Mar 26, 2012 7:03 am
All good now got it running yesterday drove it outta the shed. Now time to put the exhuast on and get it regestered then drive it again :)
