FWD Fuse??
FWD Fuse??
Hey Guys,
So recently, I made a discovery that there is meant to be a FWD Fuse, I suspect. On the sticker it says FWD, and there isn't a fuse in that spot, but it is a spot to put a fuse, Now there has never been a fuse in the time I've owned the car, but the other interesting point is that there is no Amp stated. So I don't know if it suppose to be fused or not.
Does any body know if it is or and what size?
Is it Front wheel or Four wheel? I assume Front.
Thanks guys.
Thanks guys.
It is for diagnostic purposes only. There is no normally no fuse in there. If you insert a fuse, it disables drive to the rear wheels and your Subaru becomes FWD
- FROG
Yep some autos have the provision to fit a fuse and disengage the rear end Im not sure what size.
fwd = front wheel drive in this case
- d_generate
Pretty much leave it alone unless your rear tail shaft shits itself.
