fuel gauge doesnt work on my 91 l series
every now and then when its full it will go up to 1/4 and back....
i suspect its prob the sender not the gauge?
Is this a common thing?
faulty fuel gauge
If it's a wagon, lift the rear floor cover in the cargo area, you'll see a little plate held in by a screw and some black silicone, remove this plate and you should be able to see the sender unit.purp wrote:Is that something that can be removed easily from a L?
Clean up the area around it. Unscrew the sender and be careful when lifting it out.
Packaging it up for postage could be a bit of fun I'd imagine!
