Back to the drawing board and I pulled out the light bar I had tested out on the front of the bumper a while back. This time I mounted it further up so it doesn't protrude so far forward with a couple of steel backing plates and am very pleased with the results.
Some of you may recall the bar is for a 91 or so Jeep Cherokee that I had to bend slightly to fit the curve of the bumper. It has two additional outward light tabs that can be used for top or bottom mounting.
Overall, very solid setup with good light position. :7:
And yes, the lift kit will be installed very soon...
