Brumby headlights
Brumby headlights
On the 4 headlight models what lights should be ON for low beam and high beam?
on my quad light Brumby it is the outers that have three terminals each, so run the low beam and also switch to high beam. The inners are two terminals and are only for high beam. Someone previously put in quartz halogens and one inner has wrong config and is insulated differently to the other initially causing high beam on in all lights whenever lights were on. Gotta say the two previous owners were police officers and niether noticed the problem !!
You got a problem??? The circuits can be confusing to work out if something not right
- Suby Wan Kenobi
- the gumbi brumby
