Engine cranks but won't start - no spark. Have power going to igniter, injectors etc so the ecu is functioning, just no spark.
Coincidentally there are 2 connectors not plugged in, I have no idea where they go. I have been thru every wiring diagram that I can find but none show these connectors. Both come thru the middle of the firewall and sit at the back of the engine.
One is a 6 pin plug with five wires orange blackred whiteblack brownyellow and blackyellow. The only orange wire I can find in the diagrams is the M/T neutral switch from the ecu. The other is a 2 pin plug, one red other black.
If anyone can help with info on these plugs and/or lack of spack it would be greatly appreciated
:(:(:(Cheers
Tony
 ), turned the engine a cupla times and the marks lined up perfectly
), turned the engine a cupla times and the marks lined up perfectly :):)
