info on SVX
maxxair
info on SVX
Post by maxxair » Sun Mar 30, 2008 2:01 am
hello all you knoledgeble people. tell me all you can abot these SVX autos. are they any good? does the manual button even stop the TCU changing gears? where can i get wiring info for this mess, and also after a Computer has been wet (ie underwater) will she ever go again. looks/smells like brand new, cant see any damage. cheers all.
Cheers, Rohan M.
vincentvega
Post by vincentvega » Sun Mar 30, 2008 9:46 am
yes they are a good auto, plenty strong enough behind an EJ22
if that TCU has been wet you need to disassemble it completely, clean it with a circuit board cleaner like safewash (or methylated spirits is good too) and then dry it in an oven at around 40-50deg until its completely dry.
if it has been powered up while wet its probably stuffed, but you miught get lucky.
stamp_licker
Post by stamp_licker » Sun Mar 30, 2008 8:32 pm
SVX auto manual link :http://www.hi.is/~vladisla/Detailed4EAT_vladrulli.pdf
Yep manual button will hold the gear unless its over revving.
Building a hardcore postie:D
Post by Gannon » Sun Mar 30, 2008 9:31 pm
I thought the auto in the SVX was the same as the auto found in Libertys of the same era.
Thats a good find postie
Cam
Post by Cam » Sun Mar 30, 2008 9:36 pm
Fairly sure rigolis H6 twin turbo drag wrx uses the svx gearbox so its prob strong enough for an ej22...
Post by Gannon » Sun Mar 30, 2008 9:57 pm
Cam wrote:Rigoli's H6 Twin Turbo drag WRX
Offtopic i know, but where do i find info on this beast of a car?
stamp_licker
Post by stamp_licker » Sun Mar 30, 2008 10:00 pm
Suparoo wrote:I thought the auto in the SVX was the same as the auto found in Libertys of the same era.
No they are better.
