EA82 Timing belt cover issues .
- discopotato03
Hi all , every time I go to remove EA82 inner covers the brass insert in the plastic strips and you can't remove the bolts .
Are these available new and for what sort of money ?
Cheers A .
Cheers A .
Leave em off???
I dunno how legal it is, but it looks cool
Plus you can see if your camshaft seals leak
hehehe... how true.Suparoo wrote:Leave em off???
I'd be doing the nut and bolt trick with a few washers as scrumpy said... You'd get quite a bit of muck on those belts and they're covered for a reason. If you do leave them off i'd be checking the belt condition at set intervals as I'd reckon the chance of belt failure would dramatically rise.
- Suby Wan Kenobi
Don't they just upset you greatly ? I now do them up with a little o ring to grip between bolt and cover - and not tight enough to cause grief next time around. It took me three motors to get a reasonably decent set. You almst need to surgically remove a third of the nuts surround and rebuild it with araldite or something .
